- Jan 11, 2001
Hi fellas I have recently overclocked a brand new Celeron cC0 600 to 900.
I have it on a Abit SlotKET 3 and in a Abit BH6 mobo.
I am cooling it buy using a golden orb fan and arctic silver, it has another fan right near/behind the chipset and it is sucking the hot air out. Then I have another bigger fan in the CD-Rom bays blowing air right on it.
I am using a program called Motherboard Probe (MBProbe) to check the temps, it says im running at 57C and or 135F when basically idle.
I used another program called motherboard Monitor and it said I had temps around 255F.
WTF is going on here, something is fishly, I think this is adequate cooling (I am adding 2 more fans, one to suck one to blow, towards the bottom of the case anyway) This is more cooling than friends of mine use on their relatively exact same setup.
Do you think I should worry about these temps or do you think im getting bad readings?
Thanks for you help guys!
