Good standing USB mics?
Culbrelai
I can't stand anything on my head, and my current logitech standing usb mic is dying.
Got any suggestions? I only use it for teamspeak so it doesnt have to be a huge budget breaker or anything, ideally <$40
Mpegger
For that price, the Samson Go Mic would be your best option. It's not on a normal stand, but it can clip to slim objects (it was designed for laptops) and the base has a hole big enough to fit on a standard camera mount. I have mine attached to a lamp arm from Ikea. The quality of the mic is outstanding as well as its directional qualities.
