- Feb 23, 2002
Ok i dont know if i did a bad thing but i saw a 24 volt 12 amp powersupply on ebay and was like "Ah, i could use that later when i get my water cooling peltier setup going" Its an Acopian VA24H1200M-230 which on the Acopian web site sells for about $500, i got it on ebay for $70.
well today it finally arived and i opened up the box and was like !good lord its huge! (something im sure u guys have all heard before in one way or another
) its 11x7x5, yeah im getting a 21"(H) x 16.5"(W) x 21.75"(D) sever case house it all.
Small problem though, um how do i get it to work? Im not an electrical engineer & its not like a normal powersupply where just plug into the wall and presto it works. How do i find out the watts output on this thing so that i dont overload the pelt and also where can i find monitoring equipment so i can see just how much juice is flowing through the lines to the pelt? Building a water cooling case is no big deal for me but im a total noob to electricity... which is why im begging for anyones knowledge on what and how they got working thier peltiers powersupply for a 172W DRIFT 0.8 Potted w/ Imax = 11.3 Amps, Qmax = 172 Watts
& Vmax = 24.6 Volts
Specs on the PS
Its got 7 leads labled in this order from left to right
1. out +
2. sens +
3. sens -
4. out -
5. ac L
6. ac N
7. and a funky little circle w/ a upsidedown T and 2 lines under it.
Theses are the specs:
Nominal Output Voltage 24 volts
Adjust ± V .5
Output Current Amps. at 40°C 12.0
Output Current Amps. at 55°C 10.5
Output Current Amps. at 71°C 9.0
Regulation Line* ± % .005
Regulation mv ± % .005
Ripple RMS .250
& Vmax = 24.6 Volts
Specs on the PS
1. out +
2. sens +
3. sens -
4. out -
5. ac L
6. ac N
Adjust ± V .5
Ripple RMS .250
