I having some problem on how to wire up my fans. Little info on my build. I'm doing a watercooled build. With a Z270I (mini-itx). I have 2x 240 radiator, and 5x fans total. 4x fans for the radiator and 1x case fan. I have 2 pwm fans which i plan on exhausting out the top, and 3x 3 wire fans (case fan from NXZT). 2x of the fans I'll use for intake (radiator) from the front and 1x fan for intake from back I have the NZXT manta case and it comes with a fan hub. My MOBO has CPU_FAN, AIO_PUMP, and CHA_FAN. I'm assuming that all 3 of these connection are the same? My pump is also a PWM pump. How do I wire all these up with full speed control from the MOBO or 3rd party software like speedfan?
The pump and fan hub both have a 4 pin molex, so Im assuming there wont be that 1 amp draw from the MOBO?
I've taken a picture of the fan hub from NZXT. I read somewhere that the fan hub will run the fans at 100% https://ibb.co/dvitJv
