if you missed my original post about the block i milled, go here:
http://forum.oc-forums.com/vb/showthread.php?s=&threadid=132621&highlight=critique
well, i got it leak tested and installed, though its not done yet (is it ever?
currently keeping my duron 750 @ 946 1.92vcore at 5C over system temp with only one 8cm adjustable enermax fan on the heatercore, no shroud. its a 6" x 7 3/4" x 2" heatercore btw.
i just installed it so that's load after 18 min sandra MMX burn in. i'll crank up the vcore and overclock on this puppy to see what it can really handle.
sadly, i killed my 1600 xp when trying to install this the first time, as the mounting screws i used bottomed out in the tapped hole ( i believe) and it fried. i'll have to get another
here's some pics:
Everything
close up of pump and rad:
pump and rad
i plan to get some 90 degree elbows for both the inlet and 2 outlets, and angle them toward the pump so i don't have to have this mess of tubing that is crimping on me.
tubing:
tubing
i moved some of the very messy wires so you can see the pump and the tee fitting right before the intake:
pump
EDIT: just turned off the box fan by my system and closed up the sides (i dont' have my intake fans running right now) and my system temp at 41C (ouch that's hot
) but cpu temp at 39C!
here's some pics:
Everything
pump and rad
tubing:
tubing
pump
