Yes it is unlocked as standard, you have to bridge 5th L3 to enable all the low multipliers under 12.5 I think, I did it straight away. My KT333 Epox board allows manipulation of all multipliers.
Anyway not having much joy OCing it, these TbredB cores seem to run extremely hot, I mean at the moment I am running 190x11 for 2100mhz, but it needs 1.7v, and its only a 40mhz overclock! Ive seen 57c in Prime95, about 55c on SETI. I tried 190x11.5 and got an error in Prime95 after about 3 iterations, that was with 1.825vCore, and hitting 60c.....this baby idles at over 40c!
So my initial hour or so of testing hasnt produced the results I anticipated. I reckon you need water or phase change to overclock these babies well.....
Perhaps the high FSB is limiting my processor speed overclock, so ill try a lower fsb/ high multi combo (well maybe 166x13.5 or 14) tonight. Ill also try and post some screenshots/benchies but not that impressed at 2.1ghz so gonna try for more first.
Is my coolermaster heat pipe just not good enough for this processor? Its definetely my cooling holding me back Im sure...
