So all the issues my brother and I had before are finally over. I have the new cpu and board. Did some basic settings below and stress tested. Passed a 1 hour test easy, ran the test a second time and grabbed the screenshot.
1. vcore = 1.385 in bios
2. system agent = 1.2
3. vccio = 1.2
4. dram = 1.36
How much headroom do I have left? I then did a 4.8ghz run. It failed twice. Here is the second fail screenshot. I have the vcore set to 1.420 for the second test but left the other voltages untouched from the first test. Based on the pictures, what can I do to stabilize the 4.8ghz overclock? Is it pushing too much is my concern.
Also while 4.7ghz is stable @ 1.41-1.42 vcore. I need help to figure out why if I overclock my ram to 3466 MHz the cpu stress test becomes unstable and the vcore isn't enough. Why is this happening?
Thanks in advance for all the help guys. much appreciated.
EDIT: I remember Earthdog said that the readings taken directly from the board are much more trustworthy than the software in the pictures below. I have the Asus Extreme which has the utility that reads all info from the board directly and displays it. It shows a constant 1.42-1.43 on the cpu vcore even though the pictures below show the software has readings of 1.440 & 1.456. What do you guys think? The utility more accurate than the software? Its plugging into the board directly and has sata power.
Edit #2: Cinebench results added.
Single Core = 202
Regular test = 960 (only 180 behind my 8 core mac pro xenon!)
3. vccio = 1.2
4. dram = 1.36
Single Core = 202
