Got my new SamsungPC2700 DDR. Need advice on mem settings
1eyedjak
Shreveport,Louisiana
I have the AK35GTR266A board. I don't really know how to use all the different memory setting options because I have never had a board before with the options(MSI)
I need advice on setting the memory to run the fastest it can. right now it is not overclocked.
thanks,
Mike:rolleyes:
mem timings
I run cas 2, 4 way interleave, 2, 5, 2, 4, 1t. At 2.7 volts.
You can get better FSB probably with cas 2.5 and 2t command rate.
Use Sandra to benchmark the by spd settings and then benchmark it with the new settings. Let me know if you get some improvement, and how much.
put your mem to the highest fsb while staying at cas 2 latency and then raise volts until you find a fast stable speed.
