Got things going...
jiggamanjb
MI, USA
I finally got all the water cooling into my new case I've been modding. There isn't anything else in the case yet, which is good, because there were many leaks. This is my first attempt at WC afterall. But after tightening things down, I must say it is looking nice. Here are a couple quick pics I took:
mvde
mvi8
mvid
mviv
mvjm
jiggamanjb
jiggamanjb
MI, USA
Thanks! I used the Dtek UV visible blue
http://www.dtekcustoms.com/index.asp?PageAction=VIEWCATS&Category=232
and blue antifreeze.
edit: I only used 3 drops of the dye!! It's strong stuff!
Specs are:
Via Aqua 1300
Swiftech MCW6000
Black Ice Micro 2 dual
Bay-Res Reservoir
Home Depot tubing and clamps
The CPU block is at 23C, the same as the ambient temp with no fans on the rad yet. I assume this is optimal. Just gonna let it run for a week or so to bleed it out and make damn sure there are no leaks.
Here is the case it is going in if you are interested
http://www.ocforums.com/showthread.php?t=302497&page=1&pp=30
