- Aug 14, 2014
https://www.msi.com/Graphics-card/N660Ti_PE_2GD5OC.html#hero-overview - MSI 660ti Power Edition 2gb
OK so more playtime with this beauty, stock 1097mhz-1241mhz/6008mhz, ended up with +0v 114% +65 +600 (voltage, power limit, core, mem respectively), so it boosts to 1306mhz/7204mhz on stock voltage 1.175v (ASIC is 86.6% if anyone is wondering) at 72c with Heaven on loop 2h 1080p max settings. This is with stock BIOS and zero throttling and i'm positive that it can go further if i pump the voltage because neither core or mem threw up artifacts yet. I have had an Arctic Accelero Hybrid III-140 in the drawer for months that i never got to use and was thinking about installing if possible which will help with temps.
Question time: i ran out of room TDP wise. If you refer to the 1st screenshot - modding the BIOS will only raise the total GPU power, the "normalized" will work as if nothing was changed, anything extra on the voltage or clocks or a very GPU intensive game will hit 98%+ and it starts to throttle. Is there a way around this or a hardmod for this card ?
