GPU client 404 fails
AmbientFiction
Senior Folding Zombie
Somewhere in the top 100 folders for team 32
Anyone else getting this both of my ATI cards are getting this issue:
Code:
[22:25:58] Loaded queue successfully.
[22:25:58]
[22:25:58] - Autosending finished units... [January 28 22:25:58 UTC]
[22:25:58] Trying to send all finished work units
[22:25:58] + No unsent completed units remaining.
[22:25:58] + Processing work unit
[22:25:58] Core required: FahCore_12.exe
[22:25:58] - Autosend completed
[22:25:58] Core not found.
[22:25:58] - Core is not present or corrupted.
[22:25:58] - Attempting to download new core...
[22:25:58] + Downloading new core: FahCore_12.exe
[22:25:58] Downloading core (/~pande/Win32/x86/ATI/R600/Core_12.fah from www.stanford.edu)
[22:25:59] - Error: HTTP GET returned error code 404
[22:25:59] + Error: Could not download core
[22:25:59] + Core download error (#2), waiting before retry...
[22:26:17] + Downloading new core: FahCore_12.exe
[22:26:17] Downloading core (/~pande/Win32/x86/ATI/R600/Core_12.fah from www.stanford.edu)
[22:26:17] - Error: HTTP GET returned error code 404
[22:26:17] + Error: Could not download core
[22:26:17] + Core download error (#3), waiting before retry...
Code:
[22:45:01] + Downloading new core: FahCore_12.exe
[22:45:01] Downloading core (/~pande/Win32/x86/ATI/R600/Core_12.fah from www.stanford.edu)
[22:45:01] - Error: HTTP GET returned error code 404
[22:45:01] + Error: Could not download core
[22:45:01] + Core download error (#7), waiting before retry...
restarted client after 11th failed attempt. servers are down just wait it out.
Did I miss an update? Both my GPUv2 clients are running 11.exe, not 12.
[21:12:55] + Processing work unit
[21:12:55] Core required: FahCore_11.exe
[21:12:55] Core found.
You didn't miss anything, the server became confused as to whether the card was an ATi or nVidia. Deleting the WU fixes it. The problem may be related to the latest cats. If deleting the WU doesn't work the -forcegpu ati_r700 flag should.
I have FahCore_11.exe and a FahCore_14.exe in my GPU folders, what does that mean?
It means you folded WUs that use those two cores. The p59XX gpu WUs use 14 and the rest use 11.
I don't think any WU currently uses FahCore_12, which is why it isn't in the repository.
So basically I my client tried to get ahead of itself by grabbing a core that is not in use at present moment?
Taken from Wiki and listed as an active core:
ATI-DEV (Core 12)
* Graphics Processing Unit developmental core for ATI CAL-enabled GPUS.
* Does not support SIMD optimizations.
* Available for GPU2 client only.
My guess is that this is an upcoming core and that it may very soon be in use.
**EDIT**
With a bit of digging I found the info right from the man himself
My guess was correct.
Deleted work folder, queue.dat, and unitinfo.
But before I noticed what I had done I had already deleted stuff in my SMP folder.....There goes an A3 down the toilet.......DOH!!!!!!!
Asking the obvious, isn't it in the recycle bin or trash, Ambient?
I've restored deleted work folders and que files from the bin and they've carried on folding where they left off.
ChasR:
Thanks for clearing that up, ChasR. So I'm ok with .11's then...
I have this issue with using shift+del. I hate my recycle bin and yes it does cause me issues. Like the time I deleted half of a drive full of movies.
