GPU compatible with this block?
Why not use the EK configurator at the EK site (there is a link for compatible cards on the page you linked to us!)? That will tell you. :)
https://www.ekwb.com/configurator/waterblock/3831109830772
Edit: shows ots a visual match. You can wait for someone here to respond that has the same exact setup, or reach out to EK directly jf you want to be more confident. :)
Thanks for the reply. I did use the EK config, but this specific card is not on their config. It does show a "6GD5T OC" but it does not say armor 2x so I have no clue if it's compatible. That's why I asked :)
