- Sep 22, 2002
Is it worth cooling the GPU, Can you overclock it much more when it runs cooler? Currently I have the thermaltake setup on my TI4200. And I was thinking of going with a 226 watt peltier running at 5 volts. With that efficiency I might be able to stay with air cooling? If I have to go to water to do that, thats fine. Correct me if I am wrong, but running a 226 at 5 is better than a 80 or so at 12? Same cooling with less heat? Thanks for any info. . .
Edit: currently my GPU is running at 310MHZ at about 40-50 C
