- Apr 16, 2009
- Sierra Vista, AZ
Thanks for the information. For S@H its still about how many GPUs can you run in one rig which often creates issues. So far I've had best results running 2 cards per rig. Been trying to get 3 running together, but one always seems to get to hot.
When I was folding on gpu's, I used to have four Vid cards on a single MB. I found that the best "style" of vid card for packing in the gpu's was the MSI cyclones, which kept the gpu cooler than the more traditional GPU coolers. The cyclones are more open, although you need to have decent airflow through the case to get rid of the heat since the cyclones dump heat back into the case rather than exhausting it out the back. Asus DirectCU video cards also worked well. I would use two 750w PSU slaved to each other for each rig to power the whole rig. Running 4 GTX 460s needed 8 6-pin PCIs.
