While cleaning my GPU pins with eraser found marks on the pin. Kindly let me know if I should be worry about them as this is my first Gpu (4080 ). I am very worried and paranoid. Did I just broke my GPU. It is still under warranty. Please let me know...
There was some dust in it. So tried to clean it with eraser but after cleaning found this marks. Will be out of station so before leaving cleaned the GPU and packed it and found this marks.
Done that but found the marks after using rubber so am very worried did I just damage my GPU . As this is my first pc. So very much worried. So was looking for experts comment. As this happened just the day before my travel. So cannot check also. But the card is under warranty. Thanks for your reply
Just to add, check the labeling on it. You'll want IA to be the only solvent in it. There have been cases where someone used a cleaner with fragrances and/or other solvents, which can leave a residue behind and gunk things up that way.
