- Dec 15, 2011
Hello fellow folders!
I've encountered the following problem: there are no new WU downloads for 7970 GPU, it says "Could not get IP address for assign-GPU.stanford.edu: This is usually a temporary error during hostname resolution and means that the local server did not receive a response from an authoritative server."
That last for a few days now.
What I've tried doing: - Waiting for the servers to come back online.
- Changing the flags in GPU folding slot (client-type advanced, beta, no flag)
- Deleting the contents of Work folder
- Removing and readding the GPU folding slot
- Checking and re-opening the default port for folding client
- Restarting the PC, restarting the router
Still, the problem continues as it were before. Any ideas what's wrong?
The logs:
The logs:
Code:
*********************** Log Started 2015-09-27T10:36:36Z ***********************
10:36:36:************************* [email protected] Client *************************
10:36:36: Website: http://folding.stanford.edu/
10:36:36: Copyright: (c) 2009-2014 Stanford University
10:36:36: Author: Joseph Coffland <[email protected]>
10:36:36: Args:
10:36:36: Config: C:/Program Files/FAHClient/config.xml
10:36:36:******************************** Build ********************************
10:36:36: Version: 7.4.4
10:36:36: Date: Mar 4 2014
10:36:36: Time: 20:26:54
10:36:36: SVN Rev: 4130
10:36:36: Branch: fah/trunk/client
10:36:36: Compiler: Intel(R) C++ MSVC 1500 mode 1200
10:36:36: Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
10:36:36: /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT /Qmkl
10:36:36: Platform: win32 XP
10:36:36: Bits: 32
10:36:36: Mode: Release
10:36:36:******************************* System ********************************
10:36:36: CPU: Intel(R) Core(TM) i7 CPU 920 @ 2.67GHz
10:36:36: CPU ID: GenuineIntel Family 6 Model 26 Stepping 4
10:36:36: CPUs: 8
10:36:36: Memory: 6.00GiB
10:36:36: Free Memory: 4.22GiB
10:36:36: Threads: WINDOWS_THREADS
10:36:36: OS Version: 6.1
10:36:36: Has Battery: false
10:36:36: On Battery: false
10:36:36: UTC Offset: 3
10:36:36: PID: 2116
10:36:36: CWD: C:/Program Files/FAHClient
10:36:36: OS: Windows 7 Ultimate
10:36:36: OS Arch: AMD64
10:36:36: GPUs: 1
10:36:36: GPU 0: ATI:5 Tahiti XT [Radeon R9 200/HD 7900/8970]
10:36:36: CUDA: Not detected
10:36:36:Win32 Service: false
10:36:36:***********************************************************************
10:36:36:<config>
10:36:36: <service-description v='[email protected] Client'/>
10:36:36: <service-restart v='true'/>
10:36:36: <service-restart-delay v='5000'/>
10:36:36:
10:36:36: <!-- Client Control -->
10:36:36: <client-threads v='6'/>
10:36:36: <cycle-rate v='4'/>
10:36:36: <cycles v='-1'/>
10:36:36: <data-directory v='.'/>
10:36:36: <disable-sleep-when-active v='true'/>
10:36:36: <exec-directory v='C:\Program Files\FAHClient'/>
10:36:36: <exit-when-done v='false'/>
10:36:36: <fold-anon v='false'/>
10:36:36: <open-web-control v='false'/>
10:36:36:
10:36:36: <!-- Configuration -->
10:36:36: <config-rotate v='true'/>
10:36:36: <config-rotate-dir v='configs'/>
10:36:36: <config-rotate-max v='16'/>
10:36:36:
10:36:36: <!-- Debugging -->
10:36:36: <assignment-servers>
10:36:36: assign3.stanford.edu:8080 assign4.stanford.edu:80
10:36:36: </assignment-servers>
10:36:36: <auth-as v='true'/>
10:36:36: <capture-directory v='capture'/>
10:36:36: <capture-on-error v='false'/>
10:36:36: <capture-packets v='false'/>
10:36:36: <capture-requests v='false'/>
10:36:36: <capture-responses v='false'/>
10:36:36: <capture-sockets v='false'/>
10:36:36: <core-exec v='FahCore_$type'/>
10:36:36: <core-wrapper-exec v='FAHCoreWrapper'/>
10:36:36: <debug-sockets v='false'/>
10:36:36: <exception-locations v='true'/>
10:36:36: <gpu-assignment-servers>
10:36:36: assign-GPU.stanford.edu:80 assign-GPU2.stanford.edu:80
10:36:36: </gpu-assignment-servers>
10:36:36: <stack-traces v='false'/>
10:36:36:
10:36:36: <!-- Error Handling -->
10:36:36: <max-slot-errors v='10'/>
10:36:36: <max-unit-errors v='5'/>
10:36:36:
10:36:36: <!-- Folding Core -->
10:36:36: <checkpoint v='10'/>
10:36:36: <core-dir v='cores'/>
10:36:36: <core-priority v='low'/>
10:36:36: <cpu-affinity v='false'/>
10:36:36: <cpu-usage v='100'/>
10:36:36: <gpu-usage v='100'/>
10:36:36: <no-assembly v='false'/>
10:36:36:
10:36:36: <!-- Folding Slot Configuration -->
10:36:36: <cause v='ANY'/>
10:36:36: <client-subtype v='STDCLI'/>
10:36:36: <client-type v='normal'/>
10:36:36: <cpu-species v='X86_PENTIUM_II'/>
10:36:36: <cpu-type v='AMD64'/>
10:36:36: <cpus v='-1'/>
10:36:36: <gpu v='true'/>
10:36:36: <max-packet-size v='normal'/>
10:36:36: <os-species v='UNKNOWN'/>
10:36:36: <os-type v='WIN32'/>
10:36:36: <project-key v='0'/>
10:36:36: <smp v='true'/>
10:36:36:
10:36:36: <!-- GUI -->
10:36:36: <gui-enabled v='true'/>
10:36:36:
10:36:36: <!-- HTTP Server -->
10:36:36: <allow v='127.0.0.1'/>
10:36:36: <connection-timeout v='60'/>
10:36:36: <deny v='0/0'/>
10:36:36: <http-addresses v='0:7396'/>
10:36:36: <https-addresses v=''/>
10:36:36: <max-connect-time v='900'/>
10:36:36: <max-connections v='800'/>
10:36:36: <max-request-length v='52428800'/>
10:36:36: <min-connect-time v='300'/>
10:36:36: <threads v='8'/>
10:36:36:
10:36:36: <!-- Logging -->
10:36:36: <log v='log.txt'/>
10:36:36: <log-color v='false'/>
10:36:36: <log-crlf v='true'/>
10:36:36: <log-date v='false'/>
10:36:36: <log-date-periodically v='21600'/>
10:36:36: <log-debug v='true'/>
10:36:36: <log-domain v='false'/>
10:36:36: <log-header v='true'/>
10:36:36: <log-level v='true'/>
10:36:36: <log-no-info-header v='true'/>
10:36:36: <log-redirect v='false'/>
10:36:36: <log-rotate v='true'/>
10:36:36: <log-rotate-dir v='logs'/>
10:36:36: <log-rotate-max v='16'/>
10:36:36: <log-short-level v='false'/>
10:36:36: <log-simple-domains v='true'/>
10:36:36: <log-thread-id v='false'/>
10:36:36: <log-thread-prefix v='true'/>
10:36:36: <log-time v='true'/>
10:36:36: <log-to-screen v='true'/>
10:36:36: <log-truncate v='false'/>
10:36:36: <verbosity v='5'/>
10:36:36:
10:36:36: <!-- Network -->
10:36:36: <proxy v=':8080'/>
10:36:36: <proxy-enable v='false'/>
10:36:36: <proxy-pass v=''/>
10:36:36: <proxy-user v=''/>
10:36:36:
10:36:36: <!-- Process Control -->
10:36:36: <child v='false'/>
10:36:36: <daemon v='false'/>
10:36:36: <pid v='false'/>
10:36:36: <pid-file v='[email protected] Client.pid'/>
10:36:36: <respawn v='false'/>
10:36:36: <service v='false'/>
10:36:36:
10:36:36: <!-- Remote Command Server -->
10:36:36: <command-address v='0.0.0.0'/>
10:36:36: <command-allow-no-pass v='127.0.0.1'/>
10:36:36: <command-deny-no-pass v='0/0'/>
10:36:36: <command-enable v='true'/>
10:36:36: <command-port v='36330'/>
10:36:36:
10:36:36: <!-- Slot Control -->
10:36:36: <idle v='false'/>
10:36:36: <max-shutdown-wait v='60'/>
10:36:36: <pause-on-battery v='false'/>
10:36:36: <pause-on-start v='false'/>
10:36:36: <paused v='false'/>
10:36:36: <power v='full'/>
10:36:36:
10:36:36: <!-- User Information -->
10:36:36: <machine-id v='0'/>
10:36:36: <passkey v='********************************'/>
10:36:36: <team v='32'/>
10:36:36: <user v='gabi_golan'/>
10:36:36:
10:36:36: <!-- Web Server -->
10:36:36: <web-allow v='127.0.0.1'/>
10:36:36: <web-deny v='0/0'/>
10:36:36: <web-enable v='true'/>
10:36:36:
10:36:36: <!-- Web Server Sessions -->
10:36:36: <session-cookie v='sid'/>
10:36:36: <session-lifetime v='86400'/>
10:36:36: <session-timeout v='3600'/>
10:36:36:
10:36:36: <!-- Work Unit Control -->
10:36:36: <dump-after-deadline v='true'/>
10:36:36: <max-queue v='16'/>
10:36:36: <max-units v='0'/>
10:36:36: <next-unit-percentage v='99'/>
10:36:36: <stall-detection-enabled v='false'/>
10:36:36: <stall-percent v='5'/>
10:36:36: <stall-timeout v='1800'/>
10:36:36:
10:36:36: <!-- Folding Slots -->
10:36:36:</config>
10:36:36:Trying to access database...
10:36:36:Successfully acquired database lock
10:36:36:Enabled folding slot 00: READY cpu:7
10:36:36:Enabled folding slot 01: READY gpu:0:Tahiti XT [Radeon R9 200/HD 7900/8970]
10:36:36:Started thread 5 on PID 2116
10:36:36:Started thread 7 on PID 2116
10:36:36:Started thread 4 on PID 2116
10:36:36:Started thread 6 on PID 2116
10:36:36:Started thread 9 on PID 2116
10:36:36:Started thread 8 on PID 2116
10:36:48:ERROR:WU00:FS00:Exception: Could not get IP address for assign3.stanford.edu: This is usually a temporary error during hostname resolution and means that the local server did not receive a response from an authoritative server.
10:36:59:ERROR:WU01:FS01:Exception: Could not get IP address for assign3.stanford.edu: This is usually a temporary error during hostname resolution and means that the local server did not receive a response from an authoritative server.
10:36:59:Started thread 10 on PID 2116
10:37:10:ERROR:WU00:FS00:Exception: Could not get IP address for assign3.stanford.edu: This is usually a temporary error during hostname resolution and means that the local server did not receive a response from an authoritative server.
10:37:22:ERROR:WU01:FS01:Exception: Could not get IP address for assign3.stanford.edu: This is usually a temporary error during hostname resolution and means that the local server did not receive a response from an authoritative server.
10:37:22:Started thread 11 on PID 2116
10:37:37:Removing old file 'configs/config-20150923-193235.xml'
10:37:37:Saving configuration to config.xml
10:37:37:<config>
10:37:37: <!-- Folding Core -->
10:37:37: <checkpoint v='10'/>
10:37:37: <core-priority v='low'/>
10:37:37:
10:37:37: <!-- Logging -->
10:37:37: <verbosity v='5'/>
10:37:37:
10:37:37: <!-- Network -->
10:37:37: <proxy v=':8080'/>
10:37:37:
10:37:37: <!-- Slot Control -->
10:37:37: <pause-on-battery v='false'/>
10:37:37: <power v='full'/>
10:37:37:
10:37:37: <!-- User Information -->
10:37:37: <passkey v='********************************'/>
10:37:37: <team v='32'/>
10:37:37: <user v='gabi_golan'/>
10:37:37:
10:37:37: <!-- Folding Slots -->
10:37:37: <slot id='0' type='CPU'/>
10:37:37: <slot id='1' type='GPU'/>
10:37:37:</config>
10:38:11:ERROR:WU00:FS00:Exception: Could not get IP address for assign3.stanford.edu: This is usually a temporary error during hostname resolution and means that the local server did not receive a response from an authoritative server.
10:38:22:ERROR:WU01:FS01:Exception: Could not get IP address for assign3.stanford.edu: This is usually a temporary error during hostname resolution and means that the local server did not receive a response from an authoritative server.
10:38:22:Started thread 12 on PID 2116
10:38:27:WU00:FS00:Slot ID 0 no longer exists and not yet downloaded, dumping
10:38:27:WU00:FS00:Cleaning up
10:38:27:Removing old file 'configs/config-20150923-203335.xml'
10:38:27:Saving configuration to config.xml
10:38:27:<config>
10:38:27: <!-- Folding Core -->
10:38:27: <checkpoint v='10'/>
10:38:27: <core-priority v='low'/>
10:38:27:
10:38:27: <!-- Logging -->
10:38:27: <verbosity v='5'/>
10:38:27:
10:38:27: <!-- Network -->
10:38:27: <proxy v=':8080'/>
10:38:27:
10:38:27: <!-- Slot Control -->
10:38:27: <pause-on-battery v='false'/>
10:38:27: <power v='full'/>
10:38:27:
10:38:27: <!-- User Information -->
10:38:27: <passkey v='********************************'/>
10:38:27: <team v='32'/>
10:38:27: <user v='gabi_golan'/>
10:38:27:
10:38:27: <!-- Folding Slots -->
10:38:27: <slot id='1' type='GPU'>
10:38:27: <client-type v='beta'/>
10:38:27: </slot>
10:38:27:</config>
10:38:38:Removing old file 'configs/config-20150923-210607.xml'
10:38:38:Saving configuration to config.xml
10:38:38:<config>
10:38:38: <!-- Folding Core -->
10:38:38: <checkpoint v='10'/>
10:38:38: <core-priority v='low'/>
10:38:38:
10:38:38: <!-- Logging -->
10:38:38: <verbosity v='5'/>
10:38:38:
10:38:38: <!-- Network -->
10:38:38: <proxy v=':8080'/>
10:38:38:
10:38:38: <!-- Slot Control -->
10:38:38: <pause-on-battery v='false'/>
10:38:38: <power v='full'/>
10:38:38:
10:38:38: <!-- User Information -->
10:38:38: <passkey v='********************************'/>
10:38:38: <team v='32'/>
10:38:38: <user v='gabi_golan'/>
10:38:38:
10:38:38: <!-- Folding Slots -->
10:38:38: <slot id='1' type='GPU'>
10:38:38: <client-type v='beta'/>
10:38:38: </slot>
10:38:38:</config>
10:39:59:ERROR:WU01:FS01:Exception: Could not get IP address for assign-GPU.stanford.edu: This is usually a temporary error during hostname resolution and means that the local server did not receive a response from an authoritative server.
10:39:59:Started thread 13 on PID 2116
10:42:36:ERROR:WU01:FS01:Exception: Could not get IP address for assign-GPU.stanford.edu: This is usually a temporary error during hostname resolution and means that the local server did not receive a response from an authoritative server.
10:42:36:Started thread 14 on PID 2116
10:46:51:ERROR:WU01:FS01:Exception: Could not get IP address for assign-GPU.stanford.edu: This is usually a temporary error during hostname resolution and means that the local server did not receive a response from an authoritative server.
10:46:51:Started thread 15 on PID 2116
10:53:42:ERROR:WU01:FS01:Exception: Could not get IP address for assign-GPU.stanford.edu: This is usually a temporary error during hostname resolution and means that the local server did not receive a response from an authoritative server.
10:53:42:Started thread 16 on PID 2116
11:04:47:ERROR:WU01:FS01:Exception: Could not get IP address for assign-GPU.stanford.edu: This is usually a temporary error during hostname resolution and means that the local server did not receive a response from an authoritative server.
11:04:48:Started thread 17 on PID 2116
11:20:06:Removing old file 'configs/config-20150923-214647.xml'
11:20:06:Saving configuration to config.xml
11:20:06:<config>
11:20:06: <!-- Folding Core -->
11:20:06: <checkpoint v='10'/>
11:20:06: <core-priority v='low'/>
11:20:06:
11:20:06: <!-- Logging -->
11:20:06: <verbosity v='5'/>
11:20:06:
11:20:06: <!-- Network -->
11:20:06: <proxy v=':8080'/>
11:20:06:
11:20:06: <!-- Slot Control -->
11:20:06: <pause-on-battery v='false'/>
11:20:06: <power v='full'/>
11:20:06:
11:20:06: <!-- User Information -->
11:20:06: <passkey v='********************************'/>
11:20:06: <team v='32'/>
11:20:06: <user v='gabi_golan'/>
11:20:06:
11:20:06: <!-- Folding Slots -->
11:20:06: <slot id='1' type='GPU'/>
11:20:06:</config>
11:20:24:Removing old file 'configs/config-20150923-220505.xml'
11:20:24:Saving configuration to config.xml
11:20:24:<config>
11:20:24: <!-- Folding Core -->
11:20:24: <checkpoint v='10'/>
11:20:24: <core-priority v='low'/>
11:20:24:
11:20:24: <!-- Logging -->
11:20:24: <verbosity v='5'/>
11:20:24:
11:20:24: <!-- Network -->
11:20:24: <proxy v=':8080'/>
11:20:24:
11:20:24: <!-- Slot Control -->
11:20:24: <pause-on-battery v='false'/>
11:20:24: <power v='full'/>
11:20:24:
11:20:24: <!-- User Information -->
11:20:24: <passkey v='********************************'/>
11:20:24: <team v='32'/>
11:20:24: <user v='gabi_golan'/>
11:20:24:
11:20:24: <!-- Folding Slots -->
11:20:24: <slot id='1' type='GPU'/>
11:20:24:</config>
11:22:44:ERROR:WU01:FS01:Exception: Could not get IP address for assign-GPU.stanford.edu: This is usually a temporary error during hostname resolution and means that the local server did not receive a response from an authoritative server.
11:22:45:Started thread 18 on PID 2116
