GPU temp
Sup Now
I added an external temp sensor to my 9500pro, right now the temp sits around 50-52°C...Is that high or no?
Overclocked or not, it sits about the same temp.
I have an 80mm fan on it, but the HS isn't very large, plus 2 60mm fans blowing across the board.
Temps seem ok to me, remember that gpu's are going to run hotter than a cpu and they are built to withstand higher temps than cpus. Welcome to the Forums! :clap:
