GPU Temps monitoring while playing games
craige
Guyz,
Which software should I use? to check GPU Temps. I want to know Temps while playing games, if I minimize window and check then the Temp drops…
Also, is there a proper way to check temps with sum stress test? OR gaming and seeing the best way?
Also, I would like to know CPU Temps similar way while playing games – Which software?
Your help would be appreciate.
PS: USING ATI 4870
EarthDog
Gulper Nozzle Co-Owner
Buckeyes!
Realtemp has a GPU temp in it that holds MAX temps. I woudl use that.
Furmark to stress test GPU.
burebista
Romania
RivaTuner. MSI Afterburner. EVGA Precision.
With Riva you can put on screen different plugins information (below I have data from SpeedFan plugin and RealTemp plugin).
iwan
Croatia
Guyz,
PS: USING ATI 4870
Msi afterburner.You can set to see gpu temp,core and mem clock,gpu load...
I use it on my 4850.
