Hi there
I am new to this forum, and in fact new to water cooling. Even though I have tried to research as extensively on the topic as possible before I created this thread, there are probably pieces of information I have overlooked -- sorry in advance.
I am repurposing a Dell XPS 630i case to do a bit of Litecoin mining, as a fun project. I acquired a Radeon HD 5870 (manufacturer link/TH review) for close to nothing and intend to use it in this rig. However, it is a liquid-cooled GPU, and the case is air-cooled at present. I am looking for the cheapest and quickest way to get this GPU running in my system. I am not intending to overclock the CPU higher than it is now (it runs just fine with the stock air cooler). I am not interested in having a quiet machine, as the two 120 mm fans in the case are noisy anyway and this PC will be in a separate room. As long as the GPU's temperature under load is not as high as it would be with a fan, I don't mind.
The GPU comes with its own waterblock, for the core, the memory and the VRM. Now it seems that there are at least two options for me to choose from:
1. buy pump + radiator + tank + tubing etc. and fit it to the existing waterblock. This solution would be the priciest (and probably the longest), and is the one I would like to avoid.
2. get a closed-loop CPU LC kit and remove the CPU block to have my GPU there instead. I would use an Antec H2O 620 or better yet, Dell's stock LC kit for the XPS 630i. Now what I couldn't find online is whether this makes sense at all: can I just open the loop, connect my waterblock, and voila, or is it going to be more complicated? Will there be flow capacity problems, tubing incompatibilities? What should I be aware of?
Any other suggestion? Again, I'm just looking to get this GPU running in my rig asap, noise and temperature are not a concern.
Thanks in advance for your answers!
