- Mar 7, 2008
Latest Steam Hardware Survey has a glitch in its GPU numbers. Assuming this is only a scaling error and that relative positioning is not affected, this can be corrected. And I have done. Notable changes after correction are:
1660 Super: 2.91% (+0.97). No idea what is going on here. Did someone find a boatload of them and set them up in a game cafe?
Arc: 0.19% (+0.19). A new entry as Arc finally makes it on the list. But this raises more questions. Reporting threshold is 0.15%. Could it have jumped that much in one month? Did that many Lunar Lake laptops end up in gamer's hands? Or maybe there were that many tech reviewers? Another possibility might be that Steam didn't separate out Arc before this month, and it was lumped in with "others".
7700 XT: 0.13% (+0.13). Another new entry, marking the 2nd RDNA3 dGPU to show after the 7900XTX. This is below the normal reporting threshold so only made it thanks to the glitch. This does further imply the 3rd placed RDNA dGPU must be below 0.12% share otherwise it would also similarly have made the list.
Most of the rest didn't really change much. Right at the bottom are:
4060 4.05% (-0.53)
4060 Ti 3.31% (-0.35)
3060 Ti 3.29% (-0.28)
Again don't know why these dropped. These do have some numbers behind them, but compare to 3060 for example at 5.76% (-0.10), that hardly changed. Why those in particular?
