Graphics card heat vs artifacting vs voltage question.
blackjackel
Los Angeles
So say
I overvolt my graphics card to 1.300, and at this point i'm getting artifacts at 75 degrees... then i go and....
I overvolt my graphisc card to 1.250, and at this point it doesn't artifact, even when i lower the fan speed and the temp goes above 75 degrees, its not artifacting at 78 degrees...
Does this mean my card just cant take the extra voltage? and that it doesn't have anything to do with heat?
What can I do to allow my card to take more voltage at this point? Do I have to just live with the fact that one of my cards just can't go above 1.25 while my other the exact same card can do over 1.3 easy?
[email protected]
Israel
If one card can go above 1.3 and the other cant you cant do anything with it, Its like CPU's, If you're lucky you'll get a good quality silicon, You cant do anything with it.
There is a program (I dont know what its called) that can kind of check your silicon quality.
Edit : What i wrote above is valid only if both cards clocked the same.
myndlessdayz
City of Sin
GPUz can show your ASIC score
