- Jan 18, 2001
- Athens - Greece
Like reported by a lot of benchmark, MIcroStar 6337 815E Pro is a good Mobo with great performance, especially for O/C, but have GREAT! stability problem if you want use 512Mb of memory.
The Msi specs, that you found on the manual, say that the maximum memory installable are 512Mb, like all Mobo with chipset Intel 815 Pro, but isn't true, coz if you install 2 module double side of 256Mb the system not work properly!
Probably works only with 4 x 128Mb single side module (I've not tested) or with a 512Mb module (still not tested), but absolutly not with 2 x 256Mb DS (personally tested).
Beware of this Mobo if you need to work with 512Mb, look at other brand!
