- Jan 2, 2015
- Sydney, Australia
- Thread Starter
- #21
Hey guys. Here's a quick look at some of the components and water blocks.
EK Maximus V Gene water block painted white
Polished EK Ram block with the Primochill rigid fittings that I will be using
EK Supremacy EVO CPU block polished and painted white
Waterblock installed on the motherboard
Removed the heat sink for painting
Added some white vinyl to the side of the ram slot that will be seen. The ram will also get custom graphics
Batter look with all the waterblocks on
You can also see I added some white vinyl on top of the sata connectors
White strip on the RAM though I don't like the look of it, as I said custom graphics for the RAM will be coming
Heat sink is back on the motherboard after painting. I will be making a custom plate for it with some nice ROG graphics to match the theme of the build.
That's pretty much it for now guys. Most of the red bits on the motherboard will be covered by components so they won't be seen and the build will still stick to the green and white theme.
Stay tuned for more.
Cheers,
Alex
Cheers,
Alex
