green plexi
ktn
anyone know a site where i can order green plexiglass or something i can use to tint plexi?
K
ktn
It says mirror cut on it...is that NORMAL plexi or is it like 2-way?
Paradoxmaker
Ft Worth, TX
It looks like they are mirrored sheets of plexi. You know, just like a real mirror but the glass(plastic in this case) is colored resulting in a colored mirror.
The way I read it is not mirror cut sheet but should be mirror, cut sheet.
knif_00
<So.IL>
I got my green HERE
I got my green Plexi sheets from "Sloan's Woodshop" in Tennesee. This link should take you directly to their Acrylic (plexi) Sheets page. I suggest if you are wanting Transparent colors (and green) go with Stock #913. They also have "solid" colors of Plexi. I used this on my AMD Logo I cut into the side of my rig. It looks great and when lit up with my 8 inch industrial white cathode the insides glow a nice AMD GREEN!
http://www.sloanswoodshop.com/acrylic sheets.htm
::knif_00::
