Picked up a fan/heatsink that is basically BS of what it was advertised.....said close to 50CFM air moved. Turns out it is a Vantec P3-5030.....doesn't even do much more cooling than my generic 2 fan/HS. Possible I need more grease on the SOB but I don't feel much more air coming out of it. Here is the question: Should I bother packing it up and shipping it back at a 15% restock + shipping costs, or just pick up a couple decent output 50mm fans? (Will it take a 60mm fan?) The HS itself has a much better design than my old HS. I figure with restock and shipping I could be over $12 with which I could buy 2 Top Motor 50x20mm 5800rpm, 19.5CFM fans and pay only a little bit extra for shipping. Hell I think a GORB would cool better than this HSF as it stands now. And just so I know, how much grease should there be? Should it just go on the top of the chip, or also be around the sides? (Again, wondering if I put the grease on wrong)
Here are the specs for the HSF I got:
Works with Intel Pentium III SECC2 Processors Only
Designed and tested for overclockers
Blazing 5200RPM fan speeds!
Slip-On Cap, 3-pin Power Connector for monitoring
Dual Double Ball-Bearing for superior life!
25CFM per fan, ultra Quiet
Each fan is 50x50x10mm (Total fan size 137x59x45mm)
Aluminum Alloy 6030 T5 Heatsink for FAST heat dissipation
(All I can say is the fans are marked Vantec and the design is the P3-5030....their ain't no way in hell this thing is pushing 25CFM per fan, I think I would have felt a difference in airflow over my old HSF)
If I have in fact been screwed (which it certainly appears to be the case), I caution others to avoid 3dcool.com like the plague......any helpful advice would be appreciated and laughter is fine as well (I deserve it)
