- Dec 2, 2001
- Danville, VA
ok...i know there have probably been lots of posts on this before, but I got the hole cut for my window, but I can't get the rubber to stick to the metal with the glue i was told to use...I'm using RTV glue for glueing rubber in cars around windshields and windows and stuff...I hold one little section for like 45 minutes, and as soon as i let go, it pops off...it also tends to twist out on the corners....
- what is the best glue to use?
- is there an easier way to do this?
Thanks
Marc
Thanks
Marc
