GTA SAN ANDREAS STEAM wont launch anymore . what can I do
Mikesamo
san jose CA
I cant get the game to launch. when i click on play it say srunning then nothing happens
i tried setting it to compatbilibty mode with windows 98 and it worked but all my saves are gone . im 90 % into the game and i dont wanna start over .
caddi daddi
Godzilla to ant hills
for me the version update just bjorked all my desktop links to the games and programs installed on other drives and I had to go back and make all new links.
it only mucked up the boot drive, I install everything on other drives.
I hope this helps you, I know I was pulling out what little hair I had left on my head..............
Mikesamo
Mikesamo
san jose CA
what do I do then.. I tried reinstalling the game and that didn't work . am I forced to install it on the os drive. it's a small ssd ..
caddi daddi
hmmmmm, mine just says gtav.
is the dialog, executable path not found, please reinstall game?
I just rebooted my system, can't open any games related to steam and can't sign in to steam.
Mikesamo
Mikesamo
san jose CA
I booted the game from my Windows 7 os and it worked and even the save is there. guess I'll try installing the game on the same drive as w10
caddi daddi
I don't know what to make of this "upgrade".
all my games on the same drive, that don't involve steam all load fine.
you need to check your controllers, in the flight sims, x plane, flight sim 10, airwars, my ailerons are limited to a knife edge, I can't roll inverted, and when I roll to knife edge and try to pull it around on the elevators it goes right to vertical climb, what a mess microcrap has made of this rig.......
Mikesamo
Mikesamo
san jose CA
anyway you can undo the upgrade through bios
caddi daddi
naaaa, it's windblows.
when I feel like working, instead of relaxing my first step will be to clean install all the games, if that fails it's back to win7.
if that fails........ anyboby know how to install win xp on a z97 rig??????????
Mikesamo
Mikesamo
san jose CA
never liked windows 10 anyway
Theocnoob
Near Toronto Canada
Open Steam Client>>Library>>Right click San Andreas>>Properties>>Local Files>>Verify Integrity of Game Cache (and let it run)
This has solved your issue for me with a few games after Win10 AE
