Joanna_Hammond
- Jan 29, 2017
Hi everyone,
I'm considering performing a power mod on the GTX 1080 FE. I understand that the VRM is 5 phase (50A per phase) giving a total of 250A. I'm considering a simple 10ohm bypass on the caps for C278, C271 and C263 surrounding U19 (INA 3221.) This should effectively reduce the reported power by approx 3x (apparently.) My concern is VRM temps and long-term stability of the VRM. The card currently has an EVGA Hybrid Cooler installed to reduce the temp issues this card has, so it's hovers around 46C-50C max at full load with a 210 OC. The issue now is power throttling (even with a 120% setting.)
Has anyone tried this modification? If so, what where your VRM temps and how did the mod go for you? Has any degredation of your VRM been observed?
Thanks,
Jo.
Thanks,
Jo.
