- Jan 13, 2005
Not sure what happened. Got my 3600x in the mail, updated my mobo bios on my lunch, made sure everything worked for the update, stuck the new cpu in... No video, vga light on post leds, put the 2600 back in, No video, put a r9 270 in, Video.
3600 and r9 270, video
Done screwing with it, i guess that's why credit cards were invented.
What's comparable performance wise?
Don't give a rats *** about rtx, also don't want a furnace either.
*EDIT* Used might be better, this was used and i replaced the cooler on it with an AIO and a NZXT mounting kit (worked REALLY well)
Posting from a phone will detail it better when i get the system usable.
edit:
ok up and running with a r9 270 and a 3600x. While i sat on the couch and posted this i left the computer running with the 1080 in it and the pump (AIO mounted to card) OFF and it was bone cold still after about 25 minutes so the GPU isnt getting any juice. i took my multimeter and tested for continuity across many components and none of them are blown. I did buy the card refurbed for $360 during the bitcoin video card crisis. I'm not mad it died, i am mad that other 1080's seem to cost more than that now. at least from my quicko search on the couch.
oh the reason it has the AIO with the NZXT kit on it was the stock cooler temps were really bad, i already had the AIO and i got the NZXT mounting kit cheap. Temps were very low after that, I might see 65C on a hot day and VRM was warm but wouldnt burn you (no VRM temp sensor on it)
edit:
