...and that is what testing at 1080p and higher is for. Testing lkwer doesnt show much of anything except for that res.I thought the point was to see if the CPU was holding the fps back in BF1 at 1080p or 1440p that is what he is testing.
thanks fkr your testing, but, we need to see the same scene to make a comparision.I had to install BF1 on the X58 system with Xeon X5660 @ 4.3Ghz
Here are my settings:
1080p
GPU Memory Restriction Off
Ultra preset
FPS are between 100 - 120 while playing the single player campaign where I am driving the tank. After that I am on foot scouting for the tank and I am getting 130 - 165 fps. Not sure why this is. I suck at this game. Ha!
Here is a Youtube video of a guy playing with a 6700K @ 4.7Ghz and a GTX 1080 Ti @ 2000MHz on ultra preset. He is getting as high as 180ish fps. It is a different scene but shows roughly a 10% difference on the high end.
I would like to point out that the Xeon X56xx series is not Gulftown, it is Westmere. I am still of the opinion that if you have an old 1366 system that the Xeon is a nice way to breath new life into it. Skip all of the i7's for this platform as they are cost prohibitive. I have a Nvidia reference GTX 980 that has been flashed to raise the power limits on the card and it runs very well. I have less than $200 in it. For those that still have one of these systems it can be upgraded nicely for well under $300 for a GPU and a CPU. I would *not* recommend buying a system like this today. If you don't already have one forget it.
...between a xeon amd regular cpu for all intents and purposes.
There is no difference between a xeon amd regular cpu for all intents and purposes.
perhpas in a few titles... cpu needs to be overclocked.Would an Intel Core i7-4930K 6 core 3.9GHz CPU bottleneck a GTX 1070/1080 at 1080P gaming?
Yes, those minor differences i am aware of. It doesnt change the fact that a 1080ti is being held back by the platform. The goal for the pereon is 144hz gaming...to get there, all bottlenecks should be removed as much as possible... i dont buy a 700 gpu to have it run like a 600 gpu.
Funny... a 1070 is a sweetspot gpu for 1080p to me. Considering one cant run ultra with AA on every title with a 1060...
Similar to the 700 gpu amd 600 gpu, i dont have a pc to have it look like a console either. If people are good with turning down some settings in some games, its solid. Bjt i prefer to run things on ultra with aa and over 60 fps.
Review sites test at 720p, 1080p to see if there is more FPS to be gained from the CPU, that will show if the CPU is bottlenecking at 1080p, 1440p. When you lower the resolution to 720p it does not lower the CPU instructions needed for the GPU, it increases the instructions needed from the processor to keep the GPU busy....and that is what testing at 1080p and higher is for. Testing lkwer doesnt show much of anything except for that res.
Yes.. and i disagree with that kind of testing being meaningful is my point.Review sites test at 720p, 1080p to see if there is more FPS to be gained from the CPU, that will show if the CPU is bottlenecking at 1080p, 1440p.
well aware... this is part of my point. Is there something i said to make you believe i was saying otherwise???When you lower the resolution to 720p it does not lower the CPU instructions needed for the GPU, it increases the instructions needed from the processor to keep the GPU busy.
If you want to see if a cpu is holding you back, overclock it!!When folks only test at one restitution[sic] there is know[sic] way to know...
Then he should test at 720p, 1080p, 1440p maximum, so we can see what performance he is leaving on the table in BF1.
Hi guys
I made another video with my older system but the new GTX 1080ti in Deus Ex: Mankind Divided. Everything is on Ultra or Very High (where there is no Ultra option).
Only Motion Blur is not used, since I hate that ****.
Video:
