Hello OCF,
Before we start:
GTX 590 - watercooled using XSPC GTX 590 Razor.
1x 240 Rad, 1x140 Rad.
This thread is in conjunction to my very first thread regarding my GTX 590 going 100 degrees...
I thought it was an issue with applying thermal paste, or not tightening the screws not touching the waterblock properly. But after researching in different forums I cant seem to find an answer.
So i tried to troubleshoot it by disabling SLI in NVIDIA Control Panel. Setting GPU 1 as the main Physix GPU and this made GPU 2 the active GPU.
Played games and with MSI Afterburner as my OSD, i can see GPU 2 at 99% load has a stable temp of 45 degrees Celsius.
This made me think, what if GPU 1 is broken or is getting there? Any ideas? As much as i want to use SLI, now I am stuck with single...
Thank you.
Before we start:
Thank you.
