Hi,
I have a GTX 680 Reference card which i have had and used for a little over 2 and a half years, recently my mouse has been turning it self off for a second and it is annoying when i game, so i switched usb hub to the one in the front of the case, but when i game CSGO for 2 hours or so i can hear my gpu is turning its fan RPM up, which it has never done before while playing CSGO, and since it is a reference card it throws out the heat from the back so when i feel the temperature coming out it is extremely hot and kindoff heats things around it also ( i think ), so sometimes my keyboard and mouse and mic but not sound cuts off, and wont turn on again, not even replugging the usb's or trying different usb hubs, and a restart is needed, so i thought it was my motherboard dying but now i think that its my gpu dying because it only happends when it gets warm and turns up the RPM, so my question is, could it be the gpu heating the motherboard up and causing my usb hubs to turn off?
Thanks in advance
Thanks in advance
