My load temps are low 60s with an overvolt and overclock. However, that's only at 70% GPU usage because I have VSYNC on and none of the games I own so far can max the card out at 60FPS. It's kind of pointless to ask someone their GPU temps because you can set the temps to whatever you want based on the fan curve. You could disable the fall all together and run it at 90C, or you could keep it at 100% all the time and probably never reach 60C.
