I dont see a reason it wouldnt work with laptops, expect that possibly there isnt an easily accessable +5v rail to use. I would not suggest doing it either, most laptops dont have much in the way of spare cooling available, reduce the already limited fans, and something might burn. They also dont tend to have as much drawing current as a desktop to be able to handle the mod safely, so if you must slow down you laptop fans, I would do it via resistors or voltage regulation, an easy method would be something like a 78xx fixed voltage regulator, where the "xx" is the voltage (eg. 7805=+5v regulated output).
