- Jun 25, 2004
cetoole said:I assume you mean after removing the pins, so it is quite easy. Before putting the pins back in, you just stretch out the barbs which hold the pin in the housing.
Hey cetoole, great thread, I tried the mod, using a paper clip was able to remove the pins. I had the same problem as the pins would be quite loose, what do you exactly mean by "stretching out the barbs which hold the pin in the housing"...I'm confused to what exactly your talking about, how would I go about doing it? Thanks.
BTW, the mod must have taken less than 60 second, great mod. I did notice a difference.
