Guide: Use the internals of OcBible!
MrSeanKon
See my profile....
Here at Aoaforums I created a thread.
I do not want to repeat the same posts.
Post here questions etc...
Don't ask me here what is OcBible here is its supported thread for Ocforums
The first edition of guides are available --> go to Aoaforums and download the zip file.
I will not post every time here "the new version is available etc" making unusual posts.
Thus check the Aoaforums thread to download any new editions of dlls.
When I have something important to say I will post here.
Good luck with programming! :)
MrSeanKon
See my profile....
Java# example
Although General CPU speed estimator performs fitting for five pairs someone may hate its interface.
Here is an example:
Code:
package Java_fit_example;
import System.Drawing.*;
import System.Collections.*;
import System.ComponentModel.*;
import System.Windows.Forms.*;
import System.Data.*;
public class Form1 extends System.Windows.Forms.Form
	private Approximation Fit;
	private System.Windows.Forms.Button button1;
	private System.ComponentModel.Container components = null;
	public Form1()
		InitializeComponent();
		Fit=new Approximation();
	protected void Dispose(boolean disposing)
		if (disposing)
			if (components != null)
				components.Dispose();
		super.Dispose(disposing);
	#region Windows Form Designer generated code
	private void InitializeComponent()
		this.button1 = new System.Windows.Forms.Button();
		this.SuspendLayout();
		this.button1.set_FlatStyle(System.Windows.Forms.FlatStyle.System);
		this.button1.set_Location(new System.Drawing.Point(32, 24));
		this.button1.set_Name("button1");
		this.button1.set_TabIndex(0);
		this.button1.set_Text(" Estimate");
		this.button1.add_Click( new System.EventHandler(this.button1_Click));
		this.set_AutoScaleBaseSize(new System.Drawing.Size(5, 13));
		this.set_ClientSize(new System.Drawing.Size(144, 62));
		this.get_Controls().Add(this.button1);
		this.set_MaximizeBox(false);
		this.set_MinimizeBox(false);
		this.set_Name("Form1");
		this.set_ShowInTaskbar(false);
		this.set_StartPosition(System.Windows.Forms.FormStartPosition.CenterScreen);
		this.set_Text("Fit example");
		this.set_TopMost(true);
		this.ResumeLayout(false);
	#endregion
	public static void main(String[] args)
		Application.EnableVisualStyles();
		Application.Run(new Form1());
	private void button1_Click (Object sender, System.EventArgs e)
		double msf1,msf2,msf3,msf4,volt1,volt2,volt3,volt4,input,output;
		msf1=2000;
		msf2=2050;
		msf3=2100;
		msf4=2150;
		volt1=1.5;
		volt2=1.55;
		volt3=1.65;
		volt4=1.8;
		input=1.9;
		double[] data = new double[5];       	// Let's construct the
		double[] values = new double[5];     	// necessary arrays
		values[1]=msf1;
		values[2]=msf2;
		values[3]=msf3;
		values[4]=msf4;
		data[1]=volt1;
		data[2]=volt2;
		data[3]=volt3;
		data[4]=volt4;
		output=Fit.Logarithmic(data,values,4)[1]+Fit.Logarithmic(data,values,4)[2]*Math.log(input);
		if (output > 2200.2 && output < 2200.3)
			MessageBox.Show("Approximated value is 2200 MHz");  // Actual value is 2200.29.... MHz
Just open Visual studio, copy and paste this code.
LOL I do not know Java :santa: but some commands are same with C#.
MrSeanKon
See my profile....
Solve example
Let's use the Cramer 3x3 subroutine:
Code:
using System;
using System.Drawing;
using System.Collections;
using System.ComponentModel;
using System.Windows.Forms;
using System.Data;
namespace Cramer
	public class Form1 : System.Windows.Forms.Form
		private Solve Linear_system;  // Add reference for Solve.dll
		public Form1()
			Linear_system=new Solve();   // Class initialization
		protected override void Dispose( bool disposing )
			if( disposing )
			base.Dispose( disposing );
			// Form1
			this.AutoScaleBaseSize = new System.Drawing.Size(5, 13);
			this.ClientSize = new System.Drawing.Size(248, 190);
			this.Name = "Form1";
			this.Text = "Form1";
			this.Load += new System.EventHandler(this.Form1_Load);
		#endregion
		[STAThread]
		static void Main()
		private void Form1_Load(object sender, System.EventArgs e)
			double[] solutions=new double[4];
			double[,] a=new double[4,5];       // Let's make a 3x3 linear system
			a[1,1]=1;		a[1,2]=22.5;		a[1,3]=71.25;		a[1,4]=-46.57;
			a[2,1]=2.5;		a[2,2]=71.25;		a[2,3]=23.125;		a[2,4]=-141.075;
			a[3,1]=71.25;		a[3,2]=23.125;		a[3,3]=958.3125;	a[3,4]=-487.4925;
			solutions=Linear_system.Cramer_3x3(a,5);
			if (Linear_system.Cramer_solutions() != 0)
				for (int i=1; i<=3; i++)
					solutions[i]=Math.Round(solutions[i],5);
				MessageBox.Show("x1 = " + solutions[1].ToString() + "\nx2 = " + solutions[2].ToString()
					+ "\nx3 = " + solutions[3].ToString(),"Solutions are");
			else
				MessageBox.Show("No solution can be found!","Ill conditioned problem!",
					MessageBoxButtons.OK,MessageBoxIcon.Error);
			this.Close();
Double precision variables are used.
MrSeanKon
See my profile....
Windows commands
Code:
using System;
using System.Data;
namespace System_commands
		private System.Windows.Forms.Button button2;
		private System.Windows.Forms.Button button3;
		private API Win_calls;  // It uses API.dll
		public Form1()
			Win_calls=new API();
			if( disposing )
			this.button2 = new System.Windows.Forms.Button();
			this.button3 = new System.Windows.Forms.Button();
			// button1
			this.button1.Location = new System.Drawing.Point(88, 32);
			this.button1.Name = "button1";
			this.button1.TabIndex = 0;
			this.button1.Text = "Log off";
			this.button1.Click += new System.EventHandler(this.button1_Click);
			// button2
			this.button2.Location = new System.Drawing.Point(88, 88);
			this.button2.Name = "button2";
			this.button2.TabIndex = 1;
			this.button2.Text = "Restart";
			this.button2.Click += new System.EventHandler(this.button2_Click);
			// button3
			this.button3.Location = new System.Drawing.Point(88, 152);
			this.button3.Name = "button3";
			this.button3.TabIndex = 2;
			this.button3.Text = "Shutdown";
			this.button3.Click += new System.EventHandler(this.button3_Click);
			// Form1
			this.ClientSize = new System.Drawing.Size(248, 214);
			this.Controls.Add(this.button3);
			this.Controls.Add(this.button2);
			this.Controls.Add(this.button1);
			this.Text = "Windows commander";
		#endregion
		[STAThread]
		static void Main()
		// When form is loading
			this.button1.FlatStyle=System.Windows.Forms.FlatStyle.System;  // You must change the style property
			this.button2.FlatStyle=System.Windows.Forms.FlatStyle.System;  // of boxes to enable the visual styles
			this.button3.FlatStyle=System.Windows.Forms.FlatStyle.System;
		// Implementation section
		private DialogResult result; // External variable used by next routines
		private void button1_Click(object sender, System.EventArgs e)
			result=MessageBox.Show("Please close all open applications\nand save any changes...","You will log off!",
			MessageBoxButtons.OKCancel,MessageBoxIcon.Information,MessageBoxDefaultButton.Button2);
			if (result == DialogResult.OK)
				if (Win_calls.Log_off() == 0)
					MessageBox.Show("The process failed!","FAILURE!",MessageBoxButtons.OK,MessageBoxIcon.Error);
		// Restart routine
		private void button2_Click(object sender, System.EventArgs e)
			result=MessageBox.Show("Please close all open applications\nand save any changes...","PC will be restarted!",
				if (Win_calls.Reboot() == 0)
		// Shutdown routine
		private void button3_Click(object sender, System.EventArgs e)
			result=MessageBox.Show("Please close all open applications\nand save any changes...","PC will be turned off!",
				if (Win_calls.Shutdown() == 0)
MrSeanKon
See my profile....
Variation analysis
Code:
using System;
using System.Data;
namespace Variation_analysis
		private Functions OcBible;  // Add reference for Functions.dll
		public Form1()
			OcBible=new Functions();
			if( disposing )
			// Form1
			this.ClientSize = new System.Drawing.Size(292, 266);
		#endregion
		[STAThread]
		static void Main()
			double[] data=new double[6];
			double max,min,mean,range,variance;
			for (int i=1; i<=5; i++)     // The zero element of each array is BANNED look
			{                            // in Aoaforums supported thread for more info
				data[i]=i;
			max=OcBible.Variation_analysis(data,5)[5];
			min=OcBible.Variation_analysis(data,5)[4];
			mean=OcBible.Variation_analysis(data,5)[1];
			range=OcBible.Variation_analysis(data,5)[3];
			variance=OcBible.Variation_analysis(data,5)[2];
			MessageBox.Show("Maximum is  " + max.ToString()  + ",    Minimum is  " + min.ToString()  + "\n" +
				            "Mean is " + mean.ToString() + ",    Range is " + range.ToString() + "\n" +
				            "Variance is " + variance.ToString(System.Globalization.NumberFormatInfo.InvariantInfo)
							+ "\n","Output");
			this.Close();
Of course this example does not support the BAN Technology :D
