- Apr 9, 2001
- Lehigh Valley, PA
Someone sent me this via e-mail. I've never heard of or seen this anywhere before. Is there any truth to this?:
Hi !
Great article. I also have an AXIA chiup that's running *only* at 1500 (but air cooled !!!). It's going quite hot (>50°c) but i think it's a very good result for air cooling ...
I can suggest you a mod of your KT7A board that will help to go higher if you want ...
I discovered that the KT7A is not strong enough to give the processor converters MOSFETS the current they need ... You seem to experience this problem because your MBM5 voltage screen show a low 5V line (4.93v). This is bad because when the tbird need to pump a lot of current (and it does !!!) it can't and get instable or crash.
BUT !!! There is a very simple workaround. OK see your mobo in front of you ?.
- the cpu is up and left
- pci slots are bottom and left
- between the cpu and the agp card, you'll se the SIX MOSFETS. See the middle and bottom mosfet ? Take a volmeter and measure the voltage on it's center pin : you should read 4.93v approx :that's the 5v line for your converters
- now simply connect a big section wire from the center pin of this mosfet straight to a +5v source on your power supply. This way you will help the current path to the mosfets That's it !!!
What are ther results to expect ?
- the tbird generate less heat
- you won't see a voltage drop on the +5v line (MBM5 reads 5.03 to 5.08v on mine)
- you will be able to go higher in overclocking (i gained 100mhz *and* stability)
- you will be able to step down the vcore voltage a little bit since the cpu will be more stable and less heat ...
Enjoy !
Hi !
Enjoy !
