I was wondering if my current cooling configuration was the best it could be for my specific case. I would really like to get some feedback about the specific fans I am using, in what capacity they are being used (rad fans, etc.) and if the current configuration of said fans is optimal for sufficient airflow to maintain a stable and long life for my hardware over time in my hot area.
The fans I am using are as follows:
140mm (COUGAR CF-V14HB Vortex ): http://www.newegg.com/Product/Product.aspx?Item=N82E16835553007
120mm (COUGAR CF-V12HB Vortex): http://www.newegg.com/Product/Product.aspx?Item=N82E16835553005
Below is a diagram illustrating my case fan configuration. I will also explain it in text, for those who do not wish to view the image.
x1 140mm FRONT INTAKE fan.
x1 140mm SIDE INTAKE fan.
x2 140mm TOP EXHAUST fans.
x2 120mm REAR INTAKE on H60 radiator as PUSH/PULL.
x1 120mm BOTTOM INTAKE fan, blowing air from the bottom of the case toward the top exhaust fans.
x1 120mm internal fan near drive cages blowing air from the FRONT INTAKE fan further into the case. It is low enough that it is NOT blowing on the radiator fans to blow hot air back at it. It sits sort of parallel with the GPU.
Diagram of above configuration: http://i48.tinypic.com/22ib1x.png
My second question is, are these Cougar 120mm's worth using over the stock fan that came with the H60? I know the Cougar's are rated a little lower in CFM since the CFM output is only 60 versus the 74-ish the stock one is rated at. I am also not sure what the static pressure rating is on the Cougar's. I heard they perform a little better than the Gentle Typhoon AP-15 for rad cooling. I am just trying to get a little feedback on them.
The 120mm Cougar's are coming in the mail tomorrow, so I can't just test to see what the cooling difference is on the H60 with them. However, I would love to hear any/all feedback regarding these being used over the stock fans if anyone has experience with them.
Thank you in advance for your time.
