- Jul 17, 2003
I got hacked. I got hacked good. The hacker installed 2FA when I didn't.
I've got to get it back. It's a tough road as FB does not make it easy. I was listening to NPR and they had a segment on it. Turns out that if you purchase an Occulis (SP?) Rift, you can get your account back in very little time. Then people just return the unopened Occulis. Otherwise, fill out form after form after form. Submit a copy of your ID but the system won't take it so you have to blot out the ID that is required but that the system won't take.
You guys know of a better way or any way (good or bad) that worked?
