Hey friends,
Even if I buy a new case for a brand new rig because I want 2 gpus and more breathing roo., I want to update my HAF X with a newer used mobo and cpu but my fans are noisy especially the front I had to unplug. 230mm x 30mm seems hard to find and my last 200mm needed a funky washer config. I need also a second 230mm for the door. I envision this as my R&D Linux rig. Tell me any ideas you have. I am considering some way to extend the front fan brackets but before I go chomping into my favorite case of all time, maybe someone know the best options. And I want to update the busted top front IO panel. The case otherwise is in good shape despite being made to collect dust like crazy and I blow it out weekly. The fans were inevitably going to die after 14 years.
I have see possible fans on ebay but there's gotta be a better rgb option and even a little fan system I could add. I do have access to welding gear but I want to keep the case as original as possible.
Thanks,
JIM FROM PHILLY
Thanks,
JIM FROM PHILLY
