Half-Life 2 RTX Hands-On - Path Tracing vs 2004 Original - How Far We've Come
Kenrou
"Coming to all PC gamers on March 18th, we got early access to the Half-Life 2 RTX demo - and it's stunning. In an extended version of our Retro PC Time Capsule formula, John and Alex stack up the new RTX version of the classic game running on a 12900K/RTX 5090 up against the original 2004 release version of the game, operating on period-appropriate PC hardware. How far we've come in just over 20 years!"
I saw this on Fark the other day, will def try it. IMO, HL is the series that first made a *serious* attempt to bring atmosphere into FPS games. Any chance to build on that is an excuse to replay it.
Downloaded and had a quick look around. It was an interesting test of GPU power.
Just in the starting area:
4k Ultra, DLSS "auto", FG 4x ~160fps. Looked and felt fine.
4k Ultra, DLSS "auto", FG 2x ~90fps. Looked and felt fine.
4k Ultra, DLSS "auto", FG off ~50fps. Looked and felt ok.
Latency felt fine. Indicated latency was ~30ms render, 50-60ms PC with the higher end going to FG modes. I think it was using ultra performance setting in DLSS but it still looked good.
I did notice UI elements glitched a little when FG was on. Specifically the health box on lower corner, and also the crosshairs. This looked fine when FG off. I also found a disocclusion effect on screen edges when panning regardless of FG. For example, if I turn up, the sky that was uncovered was initially different but it caught up quickly. I think both of these were related to temporal reconstruction not handling literal edge cases well where it didn't have multi-frame data to work on, or that data was impacted by the UI.
Tried turning off RR. It looked pretty bad, like AMD's FSR4 demo with unstable lighting/shadows.
Tried lower quality presets, with and without DLSS. 16GB VRAM was a limit in several cases. At sufficiently low settings without DLSS, latency was way higher than even with FG.
There's a bit of chain link fence near the start. If you look through it without moving (either the character or viewport) then it looked fine. If you did move at all, it had a kinda distorted look like it couldn't handle the data of the two.
