Hard-disc stripping
Neo Demi
Scotland
just wondering if anyones ever heard of a technique for wiping harddiscs with a 5volt supply, i heard a rumour that the major companies that fix the discs dont use software, but most of the time hook them up to a supply and blast them. just wondering if its true and how i would go about it coz ive got numerous discs that have different problems. any information would be appreciated.
I would think that would just cause more problems. Since they say that power surges damages hard drives, though a low volt like 5volt might do something.
If you want a laught, check out what 110volt will do to hardware. My work just changed its firewall settings, so I can't see the page anymore, but there is some funny stuff on there.
http://www.fiftythree.org/etherkiller/
I've never heard of it. If you want to completely erase a drive, do one of those DoD reformats. It's like a 7x re-write over the drive, and a format, or something.
I don't see how shocking the drive would do anything to clean it, though.
do you have a guide for doing a DoD format, i think that would wipe anything on my screwed up drives.
