hard drive heat and data corruption
Corruption is very unlikely since the data is protected by error correction code and will reload or retransmit.
However, as usual you should expect that 10 degrees less will give you 2 times the lifespan.
If it is still below the operating spec that should be fine. Although Seagate recently raised that from 40 C to 50 C for retail consumer drives.
I remember I read it somewhere, actually 1st thing that get affected is the "grease" in those bearing in the motors and will affects the motor's life time.
If I'm not mistaken, it sorta melted away "faster" from those balls in the motor bearing, that when the SMART number for "failed" motor start counts in. Again, I could be wrong but this makes sense.
