Hello, well not long ago my computer froze during me using it, I was watching a film, so I turned it off using the power button and went to sleep. The next day it would not turn on properly and I got several errors. I have two drives one SSD and one HDD. I tried a lot of different options and what I found is that none of them work. I tried swapping out cables, putting the drives in different ports, I tried connecting one drive at a time, and nothing works. Also I can't get to BIOS in any way, by pressing any buttons, nothing, it seems that it has been blocked or something because my computer came with a pre-installed OS. My windows is windows 8 which doesn't help at all. These are a couple of screenshots that will be of use to you guys. As you can see the only place I can go is to the boot menu, and the boot menu doens't detect either of my drives. The question is, what can I do?!
Thanks for all the attempts even if you don't help me but try,
Exteez
Exteez
