Hi guys. I have just finished building a mini gaming rig in a Coolermaster Elite 130 case.
Now, I've run into a potential problem.. it's pretty damn cool where I am right now, and my HDD temps are probably way too high.
Idling on the desktop/browsing web the hard drive is at 35c, where as in an intense gaming session (where GPU was at 65c and CPU at around 45c), my HDD temps hit a max of 50.
This is because I have the drive mounted in the area that you can put an optical drive into (it can be officially mounted there, it's not some kind of case hack).
My current case layout has a Corsair H75 radiator and one fan mounted at the front, with room behind it for a hard drive. Sadly, I can't actually mount my HDD there because the HDD power cables from my PSU have the cords coming out of the connector at 90 degrees to where it plugs in, making it impossible to mount it on flat ground (hence my decision to have it in the optical drive bay which allows the cables to hang down out the back of the HDD).
To get around this I was going to buy one of these molex to sata adaptors.
But - until I can get that, is it ok to run this PC with the HDD temps that high? Will there be a high risk of damage doing so while I wait for the cable to come? (approx 1-2 days if I order now).
Thanks
Thanks
