Hard Piping and Compression fittings
647chang
Im doing a watercooled set up with hard pipping. The hard pipe is cut a little bit longer than the opening of the fitting. Reason why is the pipe need to stick into the fitting. Im having a hard time getting pipe into the fitting. Any pointers? Am I doing somthing wrong?
Thick8
Are you certain the pipe and fittings are the same diameter? One is not metric and the other SAE? I use Monsoon fittings and pipes. The fittings fit snugly but not overly tight.
