- Jun 19, 2005
- NY
Okay, so I had a harddrive and a DVD burner burnt out on my new rig. If you look at my other threads, this is the 3/4 drive that has burnt out. So I figured something had to be causing it. The odds of 3/4 drives being bad was slim, so I bought a DMM to test the rails, formatted the array (RAID 5) with just the 3 drives, install XP SP2, install Prime95, and nothing else. Everything seems to be going fine, so I run Prime95 and here are my results:
Orange (3.3) - 3.372
Red (5) - 5.07
Yellow (12) - 12.20
NO fluctuation whatsoever. Then the machine locks up. I can't Ctrl-Alt-Delete, nothing. I try hitting the power button to do a shutdown, nothing. So I do the only thing I could do, and wince while holding the power button in to shut her down. I turn it back on thinking everything is okay, as it gets to the RAID boot manager - RAID degraded. ANOTHER drive shorted out!!! So now that the drive isn't working, Windows won't even boot properly. It's sluggish, gets to the bootscreen and just stops. A few times it made it to boot, but it doesn't seem stable. Does anyone have any ideas what could be my problem? The only thing I can think of is possibly the mobo is no good. I can't think of anything else to check. How could I figure out if it's the mobo? I bought this rig about 3 months ago or so and have slowly been putting it together. I really don't have money to spend on myself during the holidays. I know Maxtor (the 4 drives) isn't crazy about the nForce 4 chipset, but it didn't say it was incompatible - just that their diagnostic software won't work on it. Should I buy a new board and rebuild it from that? See if that solves my issue? I am ready to throw the whole damn machine out of a 12 story window at this point. I will never buy an MSI product again. I was lured in by it's Creative Labs onboard audio and it's great overclocking choices in the BIOS over the similarly specced ASUS board. If anyone can help, I'd really appreciate it. I need to know what else could possibly be burning out these drives. As it is now I still have the RMA out on the 1 drive, Maxtor won't let me RMA another one until they receive the first one. That and the fact that even if I RMA them, something is still blowing them out. Anyone have any ideas? I really appreciate it. Thanks in advance!
Red (5) - 5.07
Yellow (12) - 12.20
