[Hardware mod only] PowerHacintosh i5 - Work in progress
Ben333
Ben333
Folding for Team 32!
Pics of a successful Snow Leopard install:
Ben333
Ben333
Yup, went to the hardware store tonight and grabbed four bolts, four wingnuts, four locking nuts, four neoprene washers and four nylon washers. Those will be used to mount one of the G5 blocks to my CPU, just need to make a mount top plate.
I manually changed the CPU name from displaying as "Unknown" by editing a system file. Still need to make it display as a Mac Pro vs an iMac, I think the reason it shows as one is because this is 10.6.0 and the iMacs were probably the only Core i apples at the time 10.6 came out.
Some screen shots:
1920x1080 Desktop Screenshot
Very satisfied with this so far, good things to come!
Dooms101
under a heatsink
Wow seems great! You said you're mounting the G5 blocks on your cpu? :confused: So you're saying the G5 comes with water cooling (I don't keep up to much with Mac)?
fall
Arlington
very nice! i mis my hacintosh :( i still have the retail CD too. I think ill build a new machine just for hacintosh :D
Ben333
Ben333
Indeed, just google for G5 water cooling. A pump basically the same as a MCP355, two copper blocks, and a sweet lil aluminum radiator.
Ben333
Ben333
Well folks, a lot of trial and error! I thought I had ruined my install after updating from 10.6.0 to 10.6.6. Here's some things to note about this update, a USB rollback kext is required or your mouse and keyboard will not work, and in my case audio stopped working. My solution, enable screen sharing + VNC control in system preferences. I then did the standard software update just like on my MacBook Pro, updating everything and rebooting. Then, via VNC, did the USB rollback using multi beast and rebooted. From here, I tried many audio kexts with no luck, aswell as an audio rollback that didn't work. Finally I downloaded the latest VoodooHDA package from their website, deleted all my audio kexts installed, then installed voodoo. It's its own package, so no kext utility or multi beast required.
That's the only bit of the software side I feel the need to share, because other than that this was about as easy as installing windows. Now that I know what was needed to be done, it would indeed be that easy a second time with this board.
Some new screen shots:
Also, this Mac now has bluetooth :) BestBuy had a USB dongle for $6 or $7 on clearance so why the heck not? May be using an apple bluetooth set again.
Dooms101
under a heatsink
SB uses EFI? I didn't know that... then again I don't know a ton about EFI anyways xD I was under the impression that only Apple logic boards use EFI.
Neuromancer
Tau'ri
IIRC MSI and ASUS Sandy Bridge use EFI, Gigabyte does not yet but intends to.
Actually EFI has been in the works for a long time for PCs, Windows Vista and 7 both support it in 64bit mode.
TBH I am not sure of the particulars myself... I will look into it though.
Ben333
Ben333
Not sure, but the blog I've been reading to assist me (tonymacx86.blogspot.com) mentions OS X on sandy bridge. I mean, from where I look at it, on a non EFI system I don't really have any problems. You just install a boot loader and after you boot into OS X It's all the same anyway. That's how I understand it anyway.
Dooms101
under a heatsink
I wonder if you'd even have to use a boot loader, maybe the Apple one would work fine on an EFI board.
Ben333
Ben333
@GIXXERGUY6,
I'm not into all that flashy custom crap, I set out to convert a G5 into a Mac Pro, so keeping it as realistic as possible ;)
@ Neuro,
Negative. I installed PC EFI to the drive, replaced the DSDT.aml file, the boot file, and initially replaced the kernel... but I think the 10.6.6 update re-replaced that kernel with an Apple kernel supporting P55 anyway.
Ben333
Ben333
Well it's been a LONG day. Finally its just about done, and I'm really very happy with how it turned out. There's a bunch of pics in the middel, and more description but I'm too tired to manage all that right now. Enjoy some near finished pics I just snapped:
Progress pics to be up soon, and pics with this set up at my desk.
Anyway, I myself certainly like it, and I think I've done something that no other G5 to Intel modder has done is left it as original and standard as possible. At least in a practical way. The cooling system is great, so is apple's design with the dividers -- that's why I kept it. Very good CPU temps with everything on 5V... and on 12V this thing is in super-benching mode, sounds just like a noisy dual CPU server at boot up (because even those don't run the fans maxed all the time). I have a 20A switch in the back to toggle 5 or 12 volts, but doubt I'll ever run it on 12 unless I'm doing some heavy work and am out of the room for a while, then I suppose it's a great feature to have.
