Hardware to go with 8K7A
FishDog3
I am planing on getting the EPoX board and was wondering what your thoughts were on these other components and how well they work with the board and O/Cing.
[unorder=circle]
[#]Elsa GeForce2 Ultra
[#]Crucial PC2100 DDR RAM
[#]Maxtor Diamond max plus 60, 40GB
[#]Water cooled
[/unorder]
Other questions:
[unorder=circle]
[#]IBM or Maxtor
[#]Sound card sugustions, I'd like a nice one but would like to keep it around $80 if possable.
[#]Case sugstions, I am planning on making water cooled system, but I don't mind putting the radiator/pump external so I don't need a huge case, just a nice one that cools well.
[#]Is the RAID version worth the extra $30?
[/unorder]
Thanks you guys, and BTW this forum treats its newbies like me very well, its apreciated.
fd
Welcome to the forum FishDog3. Hope you enjoy your stay.
Back to the questions at hand.
Personaly I like IBM, the new 60gxp series is resonably priced and performs well.
Get a SBLive value card for under $50. You can't go wrong there.
Here is a good Antec case;
As far as Raid goes, I think for $30 it is well worth it, if you don't use it now, $30 is cheaper down the road than the $ for a separate Raid controller.
Good luck in your system shopping.
First, I would say go ahead and get the RAID version. It just gives you more choices for expansion.
For the hard drive, I would go with the IBM 60GXP series. I have one myself, and they work great.
For the sound card, I would say look at the Hercules Maxi Gamer or Phillips Acoustic Edge. I have an SBLive!, but have been very disappointed with the sound quality.
Finally, I must recommend a Fong Kai case. I have had mine for almost a month, and it is awesome. It is all plastic on the outside, and thus VERY quite. No more leaf blowers! They are hard to find, but I have had good luck from Directron.
I hope this helps, and welcome to the forums!
Going to agree with Vampiro here and say that I love my Fong Kai case. (I have the FK-320). I have an EpOX-8K7A and am currently running it alongside an OEM AsusTek V8200 GeForce3 and an SbLive! X-Gamer. Was a little worried about the SBLive because of the VIA686B south bridge (heard some other people were having problems). I have had none, hardware went together smoothly and it's running decently, though I haven't tried playing with the CPU multiplier jumpers yet. (I have, however, raised the fsb to 140mhz and I've also upped the GeForce3 to 220/500.) Just letting you know that these seem to work together fine. Hope that helps some.
