Has anybody used an AX-7 on a P4?
Butmonkey
I have an AX-7 laying around from an old rig, and I was thinking about buying a socket adapter to use it on my P4. Would it work? It seems like it would be an efficient cooler, as it works well on Socket A platforms.
Thanks in advance for any help,
Butmonkey.
B
Butmonkey
Well, I remember reading a review of the adapter, and clamping pressure wasn't a problem with that particular heatsink (can't recall at the moment). The only thing I'm worried about is if the copper core on the AX-7 is large enough to contact the whole P4 IHS.
Thanks again,
Butmonkey
Caffinehog
Übercaffinated Member
In the lab
Even if it doesn't, remember that the core takes up only a tiny amount of space compared to the heatspreader. Other quality heatsinks for the P4 do not cover the whole core either... the SVC sunflower comes to mind. I think you'd do better though if you sold this and got something like the slk-800-U, which is designed for a P4 setup.
